                    The inVsn ACL exists.
                    This I-SID is already configured on the fabric node.
For inVsn ACL types, specify the I-SID associated with the customer VLAN (Layer 2 VSN), the customer VRF (Layer 3 VSN), or the IP Shortcut.
For IP Shortcut traffic, the inVsn ACL match type must be both. In this case, the I-SID is zero (0).
Variable definitions
Use the data in the following table to use the filter acl i-sid command.
| Variable | Value |
| <1-2048> | Specifies the ACL ID. |
| <0–15999999> | Specifies the I-SID associated with the customer VLAN (Layer 2 VSN) or the customer VRF (Layer 3 VSN). This I-SID must already be configured on the fabric node. The InVSN Filter supports IP Shortcut traffic if the inVsn ACL match type is both. In this case, the I-SID is zero (0). Important:
                                 You can specify a Switched UNI I-SID if the I-SID is associated with a platform VLAN. |
